Surface interaction is an important topic in engineering, and it is generally recognized that the roughness of a surface has a significant impact on numerous physical phenomena, including contact, wear, friction, and heat transmission.
Nonetheless, generating rough surface models with Abaqus/CAE is quite challenging and may necessitate the usage of auxiliary tools. I present a plug-in called RSGen for automatic finite element model generation of rough surfaces in an Abaqus/CAE. RSGen supports all accessible Abaqus elements, from 2D-wire to 3D-solid. The rough surface can be constructed by importing the measured surface profile data as a text file or by entering geometrical parameters through a graphical user interface.
You can also get the plug-in through Knowledge Base article - QA00000125911
BY DOWNLOADING THIS FILE ("DOWNLOAD" YOU AGREE TO THE FOLLOWING TERMS:
THIS DOWNLOAD IS MADE AVAILABLE ON AN "AS IS" BASIS WITHOUT WARRANTY OF ANY KIND, WHETHER EXPRESS OR IMPLIED, ORAL OR WRITTEN, INCLUDING, WITHOUT LIMITATION, ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE OR NON-INFRINGEMENT.
DASSAULT SYSTEMES SIMULIA CORP., ANY OF IT AFFILIATES (COLLECTIVELY "DS:", AND ITS LICENSORS SHALL HAVE NO LIABILITY FOR DIRECT, INDIRECT, INCIDENTAL, CONSEQUENTIAL OR PUNITIVE DAMAGES, INCLUDING WITHOUT LIMITATION CLAIMS FOR LOST PROFITS, BUSINESS INTERRUPTION AND LOSS OF DATA, THAT IN ANY WAY RELATE TO THIS DOWNLOAD, WHETHER OR NOT DS HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES AND NOTWITHSTANDING THE FAILURE OF THE ESSENTIAL PURPOSE OF ANY REMEDY.
YOUR USE OF THIS DOWNLOAD SHALL BE AT YOUR SOLE RISK. NO SUPPORT OF ANY KIND OF THE DOWNLOAD IS PROVIDED BY DS.
