Connector elements in Abaqus are invaluable in building rigid and flexible multibody dynamics models. However, they can also be used to model simplified constraints and connections in routine nonlinear static analysis.
Try the attached review questions to test your knowledge of using connector elements in Abaqus! The review questions should help you identify gaps in your knowledge of connector elements that you can work on to improve your understanding.
For maximum learning, build small test problems to test the concepts discussed in the review questions and check your answers. You should be able to use the Abaqus Student Edition to build these test models.
Please let me know of any suggestions or comments.
Thanks,
Prashant
