The attached scripts can be used to relabel and renumber entities in the input file.
Relabeling Script: abq_relabel.py
This script can be used to relabel entities in the input deck with a given starting number. See the attached file for execution options.
Renumbering Script: abq_renumber.py
This script can be used to renumber node or element numbers in a given input deck. You can either renumber the nodes or elements with a starting number or shift the node or element numbers by a shifting numbers using the options provided for execution. See the attached file for execution options.
