odbJoin utility limitation
Hi All,
The odbJoin utility can be used to append restart frames to the original output database. However, in the restart analysis if you use *Model change the script throws an error "Fields are not compatible. They are either associated with different structural models or have incompatible attributes". This is a limitation of odbJoin.py script and it was lifted in restartJoin utility. Please use restartJoin for such scenarios.
Thanks
Srikanth
