Topology optimization with Tosca Structure provides optimal design suggestions from a given design space. This webcast explores how lightweight, stiff and producible design concepts can be derived in an efficient workflow including topology optimization solutions provided by Simulia. You will get an overview on the capabilities of the topology optimization module as well as the integration into the product development process and different CAE environments. Further, the setup and execution of the optimization workflow will be demonstrated using Abaqus/CAE.
In this webinar you will
- get an overview on the structural optimization capabilities provided by Tosca Structure.topology
- follow the easy setup of an optimization task using the topology optimization module included in Abaqus/CAE
- understand the integration of topology optimization in the conceptual phase of your development process.
If you like to get started with topology optimization simply check out the recording of my presentation below.
Or feel free to browse the PDF version below.
References
e-Learning: Topology optimization of a control arm - getting started with Tosca Structure (narrated video - demo of the setup, run and postprocessing of the topology optimization task in CAE)
Getting started with shape optimization for reliable and durable designs (e-Learning session - general overview on shape optimization with Tosca Structure)
e-Learning: Shape optimization of a wind turbine hub - getting started with Tosca Structure (narrated video - demo of the setup, run and postprocessing of the shape optimization task in CAE)
Efficient Design Optimization in Your CAE Environment(eSeminar recording - basic overview on Tosca Structure)
