@LW from Continental Automotive Singapore presents how he uses CST Studio Suite to model and analyze ESD field coupling from the harness to the DUT. Through the visualization of 2D field plots and 3D field animations, the root cause of the problem was identified.
Performing modeling and simulation to understand and solve electromagnetic compatibility (EMC) issues is becoming a norm in a typical product design cycle. There are various forms of EMC simulations that can be performed. Of the many types of EMC problems, electrostatic discharge (ESD) simulation provides the most benefits. This is because the results obtained through measurements can be difficult to quantify due to potential risks of equipment damage associated to it.
In this e-seminar, CST Studio Suite is used to model and analyze ESD field coupling from the harness to the DUT. Through the visualization of 2D field plots and 3D field animations, the root cause of the problem was identified. You will also learn how solutions can be conceptualized and implement through virtual prototyping so as to reap the benefits of a robust design without incurring additional costs from hardware re-spins.
Highlights:
- Learn how 3D modeling and simulation was performed.
- Learn how the simulation results can be used to locate the cause of the problem.
- Explore how virtual prototyping can be applied to formulate solutions to solve the problem in a holistic approach.
2020 e-seminars Transportation&Mobility e-seminar Champion e-seminars SIMULIA Champions
🟢E-seminar archive
