A SIMULIA e-Learning Resource
Created using Abaqus 6.12
Parallel execution in Abaqus/Explicit reduces run time for analyses that require a large number of increments and/or contain a large number of nodes and elements. For many applications the default parallel processing settings are sufficient; however, a more in-depth understanding of all parallel processing options in Abaqus/Explicit can help you use the functionality more effectively. Watch the narrated video below to learn more.
Narrated Video:
References
Summary Slides:
Click the following small image to download a printable PDF of these two slides:
Slides and Transcript:
Click the following image to download a printable PDF all slides and the transcript for the parallel execution in Abaqus/Explicit video:
Abaqus Manual References:
Abaqus 6.12 Analysis User's Manual:
--- "Parallel execution: overview," Section 3.5.1
--- “Parallel execution in Abaqus/Explicit,” Section 3.5.3
--- “Using the Abaqus environment settings,” Section 3.3.1
Abaqus/CAE 6.12 User's Manual:
--- “Controlling job parallel execution,” Section 19.8.8
System information:
--- Latest SIMULIA System Information and Requirements
--- Abaqus Release 6.10, 6.10-EF & 6.11 Performance Data
Support Articles:
--- "Configuring Abaqus for distributed memory parallel execution" Support Knowledge Base Article: QA00000008994
--- "Determining whether an Abaqus analysis can be run in distributed memory parallel mode" Support Knowledge Base Article: QA00000008423
-- More SIMULIA e-Learning Resources --
