A SIMULIA e-Learning Resource
Created using Abaqus 6.7 and Abaqus 6.12
In Abaqus/CAE you can customize the location, contents and layout of toolbars. You can create your own customized toolbars, including the functions that you use most while interacting with Abaqus /CAE. You can also create and modify keyboard shortcuts in Abaqus/CAE.
Watch the video below to learn about toolbar customization in Abaqus/CAE. Note that even though this demo was created using Abaqus 6.7, the techniques demonstrated are still applicable in to Abaqus/CAE today.
The following video includes:
- Introduction (0:00 - 1:00)
- Dockable toolbars (1:00 - 1:53)
- Custom toolbars (1:53 - 4:45)
- Custom keyboard shortcuts (1:53 - 4:45)
This video was produced using Abaqus 6.7 and can be found in the Introduction to Abaqus 6.7 web-based training site.
Now You try it!
Activate and deactivate various toolbars in Abaqus/CAE:
From the main menu bar, select View > Toolbars > Toolbar Name to change the visibility of any toolbar. Toolbars that are currently being displayed have a check mark next to their names in the menu listing.
Reposition various toolbars in Abaqus/CAE:
Click mouse button 3 on a toolbar grip to view a menu that lets you specify the location and format of the toolbar, as shown below:
Create a new customized toolbar:
- From the main menu bar, select View > Toolbars > Customize.
- On the Toolbars tabbed page of the Customize dialog box that appears, click Create.
- In the dialog box that appears, enter a Name for the new toolbar, and click OK. Abaqus/CAE creates an empty floating toolbar in the main window.
- In the Customize dialog box, click the Functions tab.
- From the Module/Toolset list, select the Abaqus/CAE module or toolset to which your desired function belongs. Abaqus/CAE populates the Functions list with the available functions in the selected module or toolset.
- In the Functions list, locate the function that you want to add to the toolbar. Drag and drop the function over a custom toolbar to add the function to the toolbar.
- If desired, add or modify the icon assignment for the selected function:
-- Select a function from the Functions list of the Customize dialog box.
-- In the Icon field at the bottom right of the dialog box, click Select.
-- In the Select Icon dialog box, select the desired icon and click OK.
Abaqus/CAE updates the icon for the selected function in all custom toolbars.- To remove a function from a custom toolbar, click the icon on the toolbar and drag it off the toolbar. Release the mouse button to delete the icon from the toolbar.
Create a custom keyboard shortcut:
- Select the Abaqus/CAE module or toolset to which your desired function belongs, and then select the function from the Functions list.
- In the Press new shortcut key field, enter the function key or key combination that you want to use, and then click Assign.
- The new keyboard shortcut appears in the Current shortcut field.
References:
-- “The Customize toolset,” Chapter 61 of the Abaqus/CAE 6.12 User's Manual
-- SIMULIA training class: Introduction to Abaqus
-- More SIMULIA e-Learning Resources --
