Crushable Foams - Polymeric & Metallic Foams
The crushable foam model in Abaqus comes from the work of Depshande & Fleck :
Deshpande,  V. S., and N. A. Fleck, “Isotropic Constitutive Model for Metallic Foams,” Journal of the Mechanics and Physics of Solids, vol. 48, pp. 1253–1276, 2000
It is an elasto-plastic model with pressure-dependent yield surface. While first developed based on work for metallic foams, it is also used for polymer foams such as expanded polystyrene foams.
Polymeric Foams
       Benchmark Manual 3.2.7 - Dytherm phenolic foam
       Expanded Polystyrene foam (EPS)
Metallic Foams (under construction)
        Aluminum foams - Deshpande & Fleck (2000)
        Aluminum Foam - Novak
Back to:  Sharing Material Test Data
Back to:  Material Modeling and Calibration - An Overview and Curriculum
