Hi All,
When you open a Abaqus/CAE file and load a plug-in that uses customData, you may get the following error message:
Warning: Some attributes of customData cannot be used or modified because their associated module could not be imported:
Module: tireWizardUtils
Attributes: tireWizard
A scenario where this issue occurs is if the plug-in is not in the working or home directory and you import customKernel module. It can also occur if the path to the plug-in module is not added to the sys.path in your case. When you launch /CAE and open CLI in Abaqus/PDE and print the below command:
>>>print '\\n'.join(sys.path)
you should see the path to the plug-in.
Thanks
Srikanth
