3DX Physics Results Explorer app Plot Sectioning Guide (Korean ver.)
Summary of 3DEXPERIENCE Physics Results Explorer: Plot Sectioning Guide
The "Plot Sectioning Guide" provides a comprehensive walkthrough on how to visualize internal sections of a model and extract physical data during simulation post-processing using the Plot Sectioning feature.
1. Overview of Plot Sectioning
This tool allows engineers to visualize hidden internal parts and perform precise data analysis on specific cross-sections.
  • Visualization Options: You can choose to display the cross-section itself, the portion "Above" the cut, "Below" the cut, or both.
  • Key Analysis Data:
    • Iso-value Data: Check the distribution of stress or strain directly on the cut surface.
    • Free Body Data: Analyze the resultant forces and moments acting on a specific section.
2. Load and Moment Analysis (Free Body Data)
Sectioning allows for a numerical understanding of how loads are transferred through the internal structure.
  • Real-time Calculation: As you drag or rotate the cut plane, the Resultant Force and Moment vectors update instantaneously.
  • Load Path Tracking: This provides an intuitive way to track the load path through the structure, which is vital for design optimization.
3. Key Settings and Controls
  • Defining Cut Surfaces: Cut surfaces can be defined using various shapes, such as Planes, Cylinders, or Spheres.
  • Position Control: Users can manipulate the section manually using the Manipulator (mouse-based) or by entering precise coordinates and orientations.
  • Sensor Tree Integration: Created cut sections are stored in the Sensor Tree, allowing for easy reuse and automatic updates when results change.
4. Business and Engineering Value
  • Design Validation: Essential for inspecting internal flow or stress concentrations in parts with complex internal geometries (e.g., manifolds, engine blocks).
  • Optimized Reporting: Transparency and edge display settings allow for the creation of high-quality, readable analysis reports.
  • MODSIM Integration: Even if the model geometry or mesh changes, the defined section sensors automatically update the results, significantly increasing analysis efficiency.
