2016 Installation Frequently Asked Questions
Question: To run the Abaqus solver from the command line, which products must be installed? Is CAE required?
Answer: Installation of both CAE and the solvers is expected
Question: To run Python on an ODB using odbAccess, which products must be installed? Is CAE required?
Answer: Installation of both CAE and the solvers is required
Question: To run only Abaqus/CAE, which products must be installed?
Answer: CAE cannot be installed without first installing the solvers
Question: If I have to install everything anyway then why split the installer in 3 portions?
Answer: This particular model for organizing installs is laying groundwork for potential future capabilities. In particular, the distinction between code and CAA installs is something that is important for 3DEXPERIENCE installations. Also, installing everything most closely mirrors the behavior of the traditional Abaqus installer and so is the normal recommendation. The flexibility that this provides is relevant in some situations but in general, installing everything is always safe and compatible with old behavior.
Question: What does CAA stand for?
Answer: Corporate term for API; Abaqus .odb API
Question: When will fe-safe use DS installer?
Answer: Scheduled for Abaqus 2018 release
Question: Can I install only the solvers?
Answer: No.  For Abaqus 2016 solvers and CAE install are both required.  There may be decoupling in the future
Question: Where do you specify port number for license server?
Answer: Same as in the past – online flexnet panel – nothing has changed
Question: Are Abaqus/CFD and Abaqus/Flow the same?
Answer: Yes, both terms are used interchangeably and refer to the same product
Question: If the solver is the same why are there two distinct media sets?
Answer: 3DX and CAE installers have the same solvers but there are some additional products installed in each case
Question: Do you need to install CAA to run Abaqus user subroutines?
Answer: Yes, CAA is required to build user subroutines
Question: Prior to install, is there any antivirus program you recommend or that is required?
Answer: No official recommendations
Question: Where are the environment files installed?
Answer: //SMA/site
Question: Do you need a new version of IE?
Answer: IE 10 is the minimum requirement for Abaqus products. You can find all system requirements in the program directory
Question: Do you need to install CAA to run .ODB scripts?
Answer: No
Question: Can you have multiple Abaqus versions on the same machine?
Answer: Yes
Question: Will you be told when fix packs are available?
Answer: No, there is no automatic notification
