Unplanned Offline Mode will be available for all SOLIDWORKS Connected apps starting with R2025x FD02:
SOLIDWORKS Visualize Connected
If there's a service outage with the Makers Cloud or a problem with your own network provider or computer that prevents a connected app from pulling a license and connecting to a collaborative space, and the app has successfully connected within the last 30 days, then Work Offline mode will be offered to you on startup from a Desktop shortcut.
While working in Unplanned Offline Mode, connections to the 3DEXPERIENCE platform are not available. You can create new documents and work locally until connection is restored.
If a connection becomes available after you launch in unplanned offline mode, then you will be notified:
Differences between Offline Mode and Unplanned Offline Mode:
Offline Mode is intended for periods of time when you plan to be disconnected to the 3DEXPERIENCE platform. For example, while traveling with a laptop. In Offline Mode:
- You can take licenses offline for a user-defined time period, up to 30 days.
- You must be online before you take your licenses offline.
- The app will not try to connect to the 3DEXPERIENCE platform until you deactivate Work Offline, or your offline period has ended.
Unplanned Offline Mode is available to allow limited usage of the app when you are unable to connect due to unplanned events or outages. In Unplanned Offline Mode:
- You can launch the app up to 30 days from your last online session.
- Work Offline is automatically set for the session.
- The app will periodically check for a connection and notify you when a connection is available.
Restrictions
Unplanned Offline Mode is not offered in case of a license error. For example, if a platform administrator removes a role and license from a platform member, then the license is denied, and the app will not launch.
Unplanned Offline Mode is not available on virtual machines (VMs).
Unplanned Offline Mode is only offered when an app launches. If an app loses connection to the license server during a session, then you must restart the app to switch to Unplanned Offline Mode. Support for mid-session failover is planned for a future release.
