Solidwork don't note female thread (M) on dimension drawing. Only diameter
I have solidworks 2022, I found this problem on melting parts.
I did and structures with melting parts, After I generated parts from every cut of the structure, then I make an assemby of thess parts to get again the structure, in this way I can do an explode of the estructure for production process.
When I generate drawings of every part of the structure happesns many problems:
1-. Doesn't insert any dimension when when try to do insert elements of the model. If the part come from a view of a single solid, then it insert all dimension of the structure and nothing is valid for this solid, If the view comes from part generated from the solid then no dimensions insert.
2-. Then I set all dimensions manually, but female thread are replaced in de next open of the drawing as diameter instead of Metric (M). It is very problematic for manufacturing because you cannot recover this hole or will give you in troubles.
Any help about that?
