Check out this interesting read from Engineering.com, "Is There A Better Approach to Design Software?" The article emphasizes how the need to collaborate among disparate engineering disciplines is ever-increasing, as is the physical displacement between members of a global design team. Dassault Systèmes’ 3DEXPERIENCE is opening up new doors in innovation, while allowing for users to collaborate effectively in real-time and across engineering disciplines.
“If you're working on a file-based system, then it's necessary to address the correct location of the files. The linking of all of the inputs and outputs was not easy. You had to create GScript files, which also had to go in a predefined location. There also was a need for a catalog to integrate the components. Whereas now, none of this matters. You just create the assembly or part template, create an engineering template file, define the inputs and your parameters, and then either use these templates manually or, through the Enterprise Knowledge Language, automate their instantiation. The 3DEXPERIENCE architecture helps enormously… It's a massive game changer.”
Read the full story here!
