Using command ‘SelectionFilter’ in DraftSight
Our standard selection techniques are useful for simple drawings however if we want more accurate selections while working on large drawing, ’SelectionFilter’ is a best option.
Here is the procedure to create a simple selection filter:
  • Type ‘SelectionFilter’ in command line.
  • In dialog box, select entity that you want to select from graphics area (e.g. Arc) using dropdown list in Filter type, click on Add button and ok. (By Default it selects 'And' as initial opearator,we can change it, if we want any other operator before selecting 'Filter Type.')
  • Dialog box will close and command window will prompt to select entities.
  • Select all entities using window selection.
And see only Arc has been selected. You can save this filter using ‘Save’ tab in Selection Filter dialog box for future use.
Below is the list of operators that can be used while creating complex filters;
AND
Entities that meet all to conditions
Lines on the TEST layer
OR
Entities that meet any of the condition
All Lines and all entities on the TEST layer
NOT
Entities that don’t meet any condition
If applied to the entity=Line
XOR
Entities that meet one or the other condition, but not both
Lines not on the TEST layer and non-Lines on the TEST layer
 Below operators can be used if you need to specify value; (e.g.radius,diameter)
Equal to any value
Equal to
Not equal to
Greater than
Greater than equal to
Less than
Less than equal to
Let’s try creating one complex filter;
Suppose we want to select only Red and Green colored lines on the screen. So this is how we can achieve this using ‘SelectionFilter’.
  • Type ‘Selectionfilter’ in command window.
  • In the dialog box, go to ‘Filter type’ and select ‘Line’ from drop down and click ‘Add’ button.
  • Select ‘Or’ for Operator and click ‘Add’ button.
  • Go to Filter type and select ‘Color’.
  • Click Add button and select Color=Red.
  • Repeat above step for Green color and click Ok.
Follow the command prompt and DraftSight is ready to select the specified entities.
