Troubleshooting Tool: Getting the gl_info.txt file
The gl_info.txt contains information about the Graphic cards and driver. It is located in the DraftSight_temp folder. The path to find it is:
For Windows 7 and Vista: C:\\Users\\%username%\\AppData\\Local\\Temp\\DraftSight_temp\\gl_info.txt
Shortcut: Start menu > type in %temp% and hit Enter.
For Windows XP: C:\\Documents and Settings\\%username%\\Local Settings\\Temp\\DraftSight_temp\\gl_info.txt
Shortcut: Start menu > Run > type in %temp% and hit Enter.
Note that the AppData and Local Settings folders are hidden by default, if you don't see type the entire path.
