Discover the Professional Pack Offering for DraftSight, loaded with unique enhancements to your free version of DraftSight for Windows. DraftSight is a user-driven product, and many of these enhancements were requested by users. We heard you, and hope you’ll enjoy the benefits these enhancements bring to your DraftSight experience.
As a special introductory offer, we invite you to try DraftSight Professional for 30 days at no cost and if you purchase by May 9th, 2014, you’ll receive a 25% discount! Register for your trial and discount code now.
What is included in the Professional Pack Offering for DraftSight?
The Professional Pack Offering for DraftSight includes all features in the free, standalone, professional-grade version of DraftSight for Windows, plus:
- Toolbox for DraftSight: A standards-based mechanical symbol library and mechanical annotation add-on created to let users insert standard hardware; generate holes; create a Bill of Material and callouts for holes; and add balloons, welding symbols and surface finish symbols.
- Design Library: The Design Library tab in DraftSight’s Task Pane provides a central location for user-defined reusable elements such as blocks. These elements are added to the drawing file and contain all properties associated with the content file such as Line Style and Layers. To use Design Library, simply drag and drop the content from the pallet into the task pane.
- Drawing Compare: DrawCompare is used to graphically compare entities between two drawing documents. The differences between the drawings are displayed in color codes. Note: Drawing Compare compares the bitmaps of two drawings at the bit level. Only visual changes are captured when the drawings are compared. For example, if you move an annotation 2mm to the left, this change is reflected in the comparison. Conversely, if you change a custom property such as the Description, this does not reflect in the comparison.
- DraftSight APIs (application programming interface) and API updates. APIs allow end users to customize and automate DraftSight. Companies that have automated, customized or integrated their current DWG-based CAD system through LISP or other macros will find significant value in these APIs.
- Batch Printing: Send a set of drawings and Sheets to printers in a batch job. Users can save batch print jobs to Batch Print List (*.bpl) files for subsequent use. Note: Users can only batch print Sheets with PageLayouts and Print Configurations associated to them, either directly for the specific Sheets or by PageLayouts stored in other drawings/ Print Configurations stored in Print Configuration files. Also, within each PageLayout and Print Configuration used in batch prints, users must specify a printer.
- Layer Preview: Quickly preview the content of layers one by one or by a set of specified layers. The command lets users examine which entities are on which layers and allows users to temporarily close the dialog box to view the layer preview without the dialog box on top.
- PDF Underlay: Attach pages of a PDF document to a drawing with the AttachPDF command. The command links the specified file as a reference to the current drawing.
- Standard Compliant Drawings: Use the VerifyStandards command to check that the current drawing conforms to industry, corporate, and custom standards. The command checks whether names and properties of Layers, LineStyles, DimensionStyles, and TextStyles in the current drawing match those in associated standards files. Users can replace nonstandard items to be compliant, flag them to be ignored, or leave them as they are.
- Mass Properties Calculations: Calculate and display the mass properties of Regions. This command reports the included area, perimeter, and centroid of the specified Region. Information about the custom coordinate system (CSS) for the Region is displayed (CCS name, CCS origin, and definition of the X-, Y-, and Z- axes of the CCS).
- Macro Recording: The quickest and easiest way to start programming with the DraftSight API is to record a macro, which contains the DraftSight API calls that correspond to the actions performed interactively in DraftSight.
- iQuestions integration: Using the Community tab, log into the DraftSight online SwYm community to search and ask questions in the iQuestions section.
- Search in Options: Simply type in the search box (from the Options menu) what you are looking for, and you will be provided with the path to the location of the topic in the Options dialog.
- Quick Group: Quickly create EntityGroups by using the right mouse button.
- Product upgrades, new releases and service packs that become available during your entitlement period.
Watch a video to see the rich features available in this new offering from DraftSight.
Learn more about the benefits of DraftSight Professional.
Get DraftSight Professional Now.
Internet and activation of the free version of DraftSight for Windows required. No minimum purchase required.
