Use the Find command to find and replace text.
To find and replace Text:
- Type Find at the command prompt.
The Find and Replace dialog box opens. - In Find what, type the Text to find.
- In Search in, specify where to find the Text. You can browse:
- on the Active Sheet/Area
- in the Entire drawing
- in a specified Selection set (click Select in graphics area to specify the entities to form a selection set)
- In Replace with, type the Text to replace the search string. Leave Replace with empty if you want to find Text but not replace it.
- Click Options to specify the entity types to include in the search and set search options.
The Find and Replace Options dialog box opens. - In Search for text in select or clear BlockAttribute values, Dimensions, Notes and SimpleNotes, Hyperlink addresses, Hyperlink text, and Tables.
- Specify whether to Match case and Find whole words only.
- In Search Results:
- click Find, then Find next, to search for the specified Text
In the Context area a text block or text line displays the corresponding content of the found Text - click Replace to replace all appearances of the found Text
- click Replace All to replace all found Text locations
- click Zoom to to zoom to the current Text location in the graphics area
- Click Close.
