Creating flyout toolbars
A flyout consists of nested commands under a button. The flyout button is recognized from the inverted triangle located at the right bottom of a button.
The procedure to create flyout toolbar is as follows:
  1. Go to Tools > Customize Interface.
  2. Expand Toolbars.
  3. Right mouse click to select New Toolbar.
4. Rename it.
5. Drag required commands to the new toolbar.
6. Select the toolbar and Right-click to select New Flyout.
7. Rename it.
8. Drag another set of commands under this flyout.
9. The sample customized flyout is as shown in the screenshot below:
As you notice, it is  available as a separate toolbar, too.
In order to activate it in UI, RMB click on toolbars > Toolbars.
Check for the newly created toolbar.
In the UI, in order to see the commands in flyout toolbar, press and hold down the button with inverted triangle.
