DELMIA Quintiq Mobile Client (DQMC) v1.5.0
Dear all,
We’re pleased to announce that DELMIA Quintiq Mobile Client (DQMC) v1.5.0 is now available.
Updated features and fixes:
General
  • Upgraded the app platform for better performance and long-term support.
  • Added translation for the More tab.
  • Fixed header title alignment when the debug indicator is shown.
  • Fixed an issue where MDM configurations did not apply correctly in the app.
  • Added support for OpenID authentication. Note: Require Quintiq 7.3.0 and Connect Lib 1.5.0 and above. Documentation: OpenID Setup.
Android
  • Quick actions on push notifications marked as low priority.
  • Date and time picker displays correctly after rotating the device.
iOS
  • Dictation in text fields, so you can enter text by voice where supported.
  • Quick actions on notifications when the app is in the background or not running.
  • Fixed a crash when scrolling items in a dropdown.
Action
  • Fixed set-page-data overwriting values that were loaded from the server.
Bottom tab bar
  • Bottom tab items can be shown or hidden based on your configuration.
Calendar
  • Full-day events are included when exporting month view to ICS.
  • You can control which calendar views appear and hide views you do not need.
  • Improved month view when many events fall on the same day.
  • Calendar state is preserved when switching between standard and split view.
  • New Max visible event count option to limit how many events show in a busy day cell.
Date picker
  • Locale chosen in app settings is applied correctly on Android.
Date & time picker
  • Time picker matches the time format set in Locale settings.
Dropdown
  • New searchable dropdown to find options quickly in long lists. See Search Dropdown documentation.
  • Dropdown can be disabled so values cannot be changed.
Geolocation
  • Geofence monitoring type now matches the type you select.
  • GPS feedback runs again after sign-out and sign-in on iOS.
List view
  • Long-press selection in multi-select always-on mode.
  • Select all visibility respects designer settings in always-on mode.
  • Grouping dropdown matches standard dropdown styling.
  • Grouping can show custom text for dynamic group options.
Main menu
  • Correct highlight when switching accounts.
  • Selected menu item stays highlighted as expected.
Matrix
  • On-change actions supported on Matrix.
Offline mode
  • Correct handling when a request reaches its final timeout.
  • More reliable requests after VPN reconnect.
  • Improved offline preloading with lower memory use and fewer out-of-memory issues.
  • Banner indicates when data is preloading.
Split view
  • Consistent behavior between persistent and non-persistent detail (including back navigation).
  • Split view restored correctly when returning from Settings on web.
  • Split view works when signing in in landscape orientation.
Stack panel
  • Flex direction styling works on web.
Table
  • On-change actions supported on Table.
Learn more about the new app and the migration process here: [DQMC]
Read the full documentation on our Support Center: [Support Center]
 Below is the list of Mobile OS versions the DQMC for iOS and Android is supported on:
iOS: iOS 26, iOS 27
Android: Android 16, Android 17
Please open a ticket in People Support in case of questions or remarks regarding these releases.
Thank you.
Kind regards,
DELMIA R&D OP&O Mobile Team
