Dear all,
We’re pleased to announce that DELMIA Quintiq Mobile Client (DQMC) v1.5.0 Beta for iOS and Android is now available.
Updated features and fixes:
General
Upgrade React Native version to 0.78 for a better performance and support.
Adds translation support to More tab.
- Fixed an alignment issue on header title when debug icon is shown.
Fixed an issue that prevented MDM configurations from being applied correctly in the app.
Android OS
Added quick action support for push notification that was flagged as low priority on Android.
Fixed an Android issue where the Date Time Picker did not render correctly after an orientation change.
iOS
Added support for dictation in text input components on iOS, allowing users to enter text using voice input.
Added quick action support for push notification when app is in background or killed state on iOS.
Fixed IOS crash issue when scrolling the dropdown items.
Action
Fixed the issue where value configured using set-page-data action will overwrote the value fetched from the server.
Bottom Tab Bar
Added toggle to enabled and disabled bottom tab item.
Calendar
Fixed the issue in calendar component where full day events are excluded when exporting to ICS file in month view.
Added support to toggle Calendar view mode and allowing user to hide it.
Fixed a visual issue with calendar month view when there are many events within a single date cell.
Added state cache mechanism to preserve page state across different view (normal view/split view).
Added support to a new parameter named `Max Visible Event Count` for calendar component.
Date Picker
Fixed an issue where the locale selected in the app setting not being applied for Android device.
Date Time Picker
Fixed an issue where the Time Picker dropdown did not match the time format configured in Locale Settings.
Date Time Range Picker
- Fixed data binding issue in Date Time Range component where data was not being retrieved from the page data.
Dropdown
- Introduced a new dropdown component with built-in search functionality, enabling users to quickly find and select items from large lists.
Added ability to disable the dropdown value from being modified.
Geolocation
- Fixed an issue where the geofence monitoring type always returned Concurrent regardless of the selected monitoring type.
Fixed an issue where GPS Feedback did not trigger after a user logged out and logged back in on iOS.
List View
Added long press support for checkbox with always-on mode.
- Fixed an issue where in checkbox always-on mode, deselecting Select All in Designer did not hide the button.
Fixed the list component to display the same dropdown as a standard dropdown.
Introduce new configuration property for listview grouping to show alternative text for dynamic group selection option.
Main menu
Fixed an issue where main menu highlighted state is not behaving correctly when switching accounts.
Fixed an issue where the selected main menu item was not highlighted correctly.
Matrix
Add on-change action support to Matrix component.
Offline mode
Fixed an issue where final timeout behaviour was not parsed correctly when a timeout occured.
Fixed a VPN network issue that caused the request to fail after reconnecting.
Fixed memory leak issue with offline data preloading. Efficiency of the loading mechanism is now improved and would not cause out of memory app crash.
Added information banner to indicate data preloading status.
Split View
Standardized the behavior of SplitView between persistent and non-persistent configuration.
Fixed split-view display when navigating back from Setting page in web.
Resolved an issue where split-view mode did not function correctly when login in landscape orientation.
Stack Panel
Fixed issue where flex-direction styling did not work in web.
Table
Add on-change action support to Table component.
The Beta will close on November 6, 2026.
Install the Beta from the following link:
iOS: https://testflight.apple.com/join/hvugHphd
Android:
-Join on Android: https://play.google.com/store/apps/details?id=com.delmia.quintiq.rengine
-Join on the Web: https://play.google.com/apps/testing/com.delmia.quintiq.rengine
Please refer to the following link for Instructions to install the Beta:
Android: https://support.google.com/googleplay/answer/7003180?hl=en
Below is the list of Mobile OS versions the DQMC for iOS and Android is supported on:
iOS: iOS 26, iOS 27
Android: Android 16, Android 17
Thank you.
Kind regards,
DELMIA R&D OP&O Mobile Team
