Dear all,
We’re pleased to announce that DELMIA Quintiq Mobile Client (DQMC) v1.4.0 is now available.
Updated features and fixes:
General
Proxy group field in the Settings page can now be saved persistently.
Improved app stability by resolving internal dependency issues.
Added build number in app version for better tracing.
Renamed Espanol to Español in Locale Settings page.
Fixed an issue on visualizing array based data from HTTP Handler API.
Android OS
Fixed an issue on Android where push notifications were sometimes not clickable.
Improved add-calendar-event action on Android with calendar selection support.
Web App
Fix an issue where refresh-on-exit action does not work in DQMC web app.
DQMC web app now can be hosted in subpath/subfolder under webserver document root. Documentation: Deploy web build
Calendar
Introduced the ability to update existing events in Add Calendar Event action.
Standardize full day event behaviour across week and month view, tapping on the event now navigates user to day view.
Added new feature where user can batch add and update events to device calendar.
Allow configuration event title when exporting calendar events to ics file.
Date Picker
Fixes a bug that can happen on timezones trailing UTC - when a date picker had its value set, it could appear to set it to the previous date instead of the selected one.
Fixed an issue where DateTime Picker component did not update correctly when used with page-data binding and refresh component action.
Date Time Picker
Standardized minute interval behavior in Time Picker component for iOS and Android.
Date Time Range Picker
Fixed data binding issue in Date Time Range component where data was not being retrieved from the page data.
FAB
Fixed FAB items position to follow the position of FAB in the page.
Geolocation
Fixed a crash issue during app launch when geofencing feature is enabled.
Icon
Custom icons containing invalid or corrupted data will now display a default placeholder icon instead of causing the app to crash.
Label
Added strikethrough feature to label component.
List View
List view with grouping now shows multi selection option on group header.
Fixed an issue where selecting the all group headers did not update the state of the top header checkbox.
Offline mode
Modified the logout warning dialog behavior to only be prompted when user has at least one pending write request.
Improved offline mode stability by fixing API timeout issue.
Fixes an issue in offline mode where data not behaving correctly when using set-state feature.
Introduce Server Heartbeat feature which can be used to enabled periodic check for backend server availability from DQMC app.
Fix and align offline state data merging behavior for some edge cases.
Fixed the last-updated timestamp for offline page to show the actual time when the data is fetched.
Fixed the offline-data preloading issue in with small delay.
Optimized the configurations for offline data-preloading mechanism.
Fixed an issue where the network status was not updating correctly after logging out.
Push Notifications
Fixed an issue where notification unread count is not updated when a notification is deleted form the list.
Fixed a visualization issue with notification action title when language text binding is used.
QMC authentication
Removed authorization header from API request for SAML flow.
Resolved an issue where SAML re-login did not work correctly after session expired.
Sortable
Improved sortable component stability by adding safety checks to handle incorrect binding values and prevent unexpected re-render crashes.
Split View
Introduced Split View feature for larger devices, displaying the master an detail pages side by side when the screen width meets the required threshold.
Learn more about the new app and the migration process here: [DQMC]
Read the full documentation on our Support Center: [Support Center]
Below is the list of Mobile OS versions the DQMC for iOS and Android is supported on:
iOS: iOS 18, iOS 26
Android: Android 10 and above
Please open a ticket in People Support in case of questions or remarks regarding these releases.
Thank you.
Kind regards,
DELMIA R&D OP&O Mobile Team
