DELMIA Quintiq Mobile Client (DQMC) v1.3.0 Beta
Dear all,
We’re pleased to announce that DELMIA Quintiq Mobile Client (DQMC) v1.3.0 Beta for iOS and Android is now available.
Updated features and fixes:
General
  • Fixed an issue where hidden notification will not trigger on-created action as per defined in mobile designer.
  • Changed description for mic permission for video recording for file uploader component
  • Fixed a security issue where Apple's App Transport Security (ATS) restriction has been bypassed
  • Added option to remember or clear user credentials when logout confirmation dialog is hidden
  • Introduce a new feature App version validation to validate DQMC version in user device during login. Failed validation will block user from login. Documentation: https://support.quintiq.com/doc/dqmc/features/app_version_validation
Android OS
  • Improved the scrolling performance of the List View component when multi-select is enabled.
  • For Android releases, we have aligned the minimum support for Android version to Android 11.
iOS
  • Fixed a security concern on geolocation permission
  • Fixed issue in Settings page where some switches are not responding.
Web App
  • Fixed scrolling issues for ListView when in responsive mode in Web App.
Bottom Tab Bar
  • Resolved a styling issue with the bottom tab component when a default tab is set.
  • Color palette can now be used to set as the icon color of bottom tab's icons.
Calendar
  • Fixed issue in calendar component where Today button is not responsive when current view is showing something that earlier than current date
  • Fixed the calendar component in interactive mode to refetch data when user tap on single date cell
Chart
  • Fixed a crash issue on scatter chart when stacked and bubble is enabled.
Collapsible Panel
  • Fixed issue where collapsible panel child component call API twice upon re-rendering
Date Time Picker
  • Added minute interval feature to date time range picker.
  • Fixed Android crash issue when opening date time picker with minute interval configured.
Date Time Range Picker
  • Fixed date time range picker not behaving correctly when End date is updated.
  • Fixed an issue that caused the date-time range picker's visibility to not work as expected.
  • Fixed an issue in the date time range component where updates were triggered when both dates had the same value.
Duration Picker
  • Add language support for Duration Picker component.
  • Fixes the freezing issue that were happening when duration picker triggered the page refresh.
Editor
  • Designer now supports numbers & punctuations keyboard type for Editor component
Icon
  • Fixed the issue of icon color doesn't reflect when svg string with fill attribute is used.
  • Fixed the issue of custom icon not rendered in selected bottom tab.
  • Now the custom icon that contains corrupted string or attack string will be rendered as the default question mark icon instead of crashing the mobile app.
Label
  • Added strikethrough style support for label component in the designer.
Main Menu
  • Improved main menu by maintaining collapsible category list's expanded/unexpanded states.
Offline mode
  • Added new capabilities to offline-mode that allow create, read, update & delete data during offline.
Push Notifications
  • Fixed issue for android app to send notification after a cold device restart
  • Resolved an issue where iOS push notification is not shown in notification center when the device is locked.
  • Fixed an issue where android app might not receives notification after an period of inactivity.
  • Fixed an issue where notifications are not shown in android device when the app is in background, and the notifications are configured to be shown in dialog.
QMC authentication
  • Enhanced SAML security, usernames are now securely hashed before being returned during SAML login and logout.
RFID Reader
Table
  • Fixed an issue in table and matrix component where text is not display when inputType is Real.
The Beta will close on April 24, 2026.
Install the Beta from the following link:
iOS: https://testflight.apple.com/join/hvugHphd
Android:
-Join on Android: https://play.google.com/store/apps/details?id=com.delmia.quintiq.rengine
-Join on the Web: https://play.google.com/apps/testing/com.delmia.quintiq.rengine
Please refer to the following link for Instructions to install the Beta:
Android: https://support.google.com/googleplay/answer/7003180?hl=en
Below is the list of Mobile OS versions the DQMC for iOS and Android is supported on:
iOS: iOS 18, iOS 26
Android: Android 15, Android 16
Please open a ticket in People Support in case of questions or remarks regarding these releases.
Thank you.
Kind regards,
DELMIA R&D OP&O Mobile Team
