DELMIA Quintiq 2021 Refresh2 release
Quintiq SoftwareRelease
We are glad to announce that DELMIA Quintiq 2021 Refresh2 is now available.
Please click below to learn more about this release:
Installer Packages | Release Notes
Highlights
  • Web Client: Starting this release the Web client can be used without preliminary license. Further the most notable change is the use of new icons.
  • Dataset Store Replication: An (active) dataset store can be replicated to multiple (mirror) dataset stores for redundant disk storage of the data.
  • Large View Files: The size of Thin Client View files is significantly reduced both on disk and in memory.
  • Memory Improvements: Due to a change in the way the variable data (strings and binaries) are stored, has reduced the size of transaction history.
  • Audit trail Enhancements: The Audit trail UI has been extended for the web client, the auditing of relations has improved, and toggling IsAudited now shows the expected values.
  • Quill Improvements: The format of constraints and KPI attributes has been changed to normal Quill, and a number of useful new quill methods have been added to avoid code duplication, and boiler-plate code.
  • REST Endpoint Validation: The Rest Endpoint has been extended to support the validation of values (e.g. maximum, regex, etc). In addition, additional validation can be done in the model to return HTTP error codes.
  • Parser Improvements: The compiler is fully based on the new multi-pass compiler pipeline. After syntax checking in 2020 Refresh2 (6.1.2), this release adds compiling (determining bindings and code generation).
> Read more...
Contact information
Please do not hesitate to contact DELMIA Quintiq Customer Support with any questions you may have. You can contact the team by submitting a request in the 3DSupport App or via phone:
• Netherlands: +31 73 648 8070
• United States: +1 866 928 9438
• Australia: +61 3 9207 5055
• Malaysia: +60 3 7494 9199
• China: +86 21 2060 5353
Kind regards,
DELMIA Quintiq R&D team
