I'm looking for the V6 / 2023x equivalent of the V5 "right click > components > define contextual links" capability.
By using this command in V5, I could repair broken links, or modify the node path from publication parent to publication child however I needed to if I'd moved things around in the specification tree, and then Catia would automatically reconnect all other broken links which had used that node path. The V5 tool would also allow me to change the design context of a part that had been originally designed in a different context so that it could accept imported publications (with links) from the new context.
The closest tool that I've found in V6 is the "Links and Relations" tool, but this tool is much more limited in its functionality. The new tool doesn't seem to be able to repair broken links, nor does it seem to be able to manually change the context of a part.
Is there another tool that I'm looking for, or is this functionality simply lost in V6?
Many thanks in advance!
