Hi CATIA lover, Today I am showing you the engine block design made by using part design.
The engine block is the hub of the vehicles that run on internal combustion, providing the powerhouse for the vehicle. It is called a "block" because it is usually a solid cast car part, housing the cylinders and their components inside a cooled and lubricated crankcase. This part is designed to be extremely strong and sturdy because its failure results in the failure of the car which will not function until the engine block is replaced or repaired. Engine blocks are normally cast from either a suitable grade of iron or an aluminum alloy.
CATIA Mechanical Design Engineering Plastic Part Engineering Reverse Engineering car designing
