i'm new to the group so my apologies if i'm placing this question in the wrong place.
where i work we use an add-on called dynavista. in my design group, dynavista is primarily used for surfacing work to aid in the design of stamping dies but it has other capabilities. one of these capabilities is in the "dynavista assembly" workbench, there is a command called "activate/deactivate arrangement". what this command does is it will activate/deactivate a component plus do the same for any published body associated to this component in other parts.
what i'm trying to do, is write a rule that will allow me to turn this command on/off for several components with a single parameter.
my problem is, i cannot find the verbiage that will allow me to control the "activate/deactivate arrangement" command.
i'm hoping someone has already crossed this bridge & knows the answer.
thanks in advance if you've got the answer.
