This is the command which you want to use when you want to do a batch job to import or export different objects in or out of the 3DEXPERIENCE platform. As you can observe, there are a lot of possibilities, you can search in the documentation for what can be done. This example shows an export in stp file format for several files from the platform. Be aware of how the search is done. Starting with minute 4:50 you will see the black window showing different steps done in the background of the export. https://youtu.be/TJgCwSMafDs
