3DEXPERIENCE R2018x_NewFunction [Civil Engineering]: Rebars creation
Highlight is delivered as a new App Concrete Structures 3D Design to provide user the ability to create quickly and easily reinforcing bar layers (rebar) with respect to standard business rules.
Requirement origin
In civil engineering design, the traditional 2D drawings are not enough for lean construction management. BOM of reinforcement from 2D drawings is not consistent with real construction site and makes sometimes impossible the management of reinforcement process. It is also not easy to track design changes (frequent in projects) with 2D drawings because of technical issues.
Using this command user can generate standard, parametric, positioned and customized rebar geometry.
What is offered & how it serves
The Rebar creation command offers 4 distinct possibilities for the user to define a bar profile.
1: Rebar Template profiles
In this mode, user can shape his bars from UDF stored in data base.
2: Rebar from explicit wire selection or creation
In this mode the user can create the rebar using a wire or define a wire using existing points.
3: Rebar strap design
Using this modes user can create a rebar layer around an existing rebar layer
4: Rebar mesh design
Using this modes user can create a new Rebar layer on another layer.
*In this post we will be going through only ‘Rebar Template profiles’ method.
Let us see the new commands that are provided in this highlight through a short video.
Rebar Template profiles:
The UDF are embedded in Reinforcing bar Object Types. A 3D Search is proposed in the Rebar creation command to get access to those Object Types
DS provides default Object Types to start with the most commonly used profile shapes. Those profiles are available in a 3dxml file that can be imported into the 3D Experience platform. This content can be found in the \\startup\\Civil\\Rebars directory.
Two kinds of Object Types are available:
  • Fixed profiles (red bar icon in 3DSearch):
When the fixed bar is selected, all the bars contained in the Rebar bed will have the same shape (same length, same number of bends…) that is why we call it Fixed.
As see in following picture, there is only one input for this bar ‘Axis Systems’ that enables to locate the bar in 3D geometry area.
Let us see the working of fixed type of rebar profile through a short video.
  • Adaptive profiles: Profiles shaped by delimiting surfaces.
In case of complex rebar design, the bar profile is not always straight but must be bent to follow the boundaries of the concrete body. By choosing an adaptive profile, the bar profile embraces some selected bounding surfaces and keeps associativity with them.
There are two types of Adaptive profiles:
  • Adaptive LP (purple bar icon in 3DSearch): (LP = Limiting plane)
If this kind of bar is selected, all the bars contained in the Rebar layer will adapt to the limiting surfaces (computed automatically or selected by user).
Those delimiting surfaces must be plane surfaces.
Let us see the working of Adaptive LP type of rebar profile through a short video.
  • Adaptive FS (black bar icon in 3DSearch): (FS  = Following Surface)
If this kind of bar is selected, all the bars contained in the Rebar layer will adapt to the limiting surfaces (computed automatically or selected by user). Same as for Adaptive LP. But here the limiting surfaces can be curved surfaces.
The shape of the bars can be different as it depends on the surrounding surfaces.
Let us see the working of Adaptive FS type of rebar profile through a short video.
References
3D Modeling | Multi Discipline Engineering | Concrete Structures 3D Design | Creating Rebars | About Rebar Creation
AEC
