Using Path Variable for Excel sync file location in Cameo
Hello all - I'm trying to figure out if the following is possible. In Cameo Environment settings, there is a way to create path variables to find files near the Cameo install or other key locations. I created a custom tag that pointed to a directory in my C:\\Users area in Windows.
I then used this path variable to locate a sync file for Excel/CSV Sync. When I click the open folder, it goes to the correct location. However, once I am done the path variable with expand. I also cannot manually set the URL with it. Is there something I am missing or is this just not feasible? I am trying to set the path variable so that multiple people collaborating on a Cameo model can use the sync to share data with non-modelers without changing the path every time a different modeler wants to sync.
