Please check our latest how-to and learn in the shortest time how to debug SysML simulations.
1. Common Issues
- Incorrect or incomplete SysML model
- To execute action you require tokens in all action inputs
- State does not stays active if transition from state has no trigger or guard
- No signals on sent / accept event actions
- Parametric diagram constraint block parameters are not connected
- Elements in the model are not the same as in the diagram
- Deleted symbol from diagram but not from the model (use Ctrl + D)
- Copy pasted symbol in diagram.. Element is still the same
- No classifier behavior is assigned
- Classifier behavior is assigned but execution is not in context
- Variable names does not match
2. Common Time Issues
- Time parameters are not specified
- Clock does not start
- No duration constraints – time is based on animation speed
- Chart refresh rate is too high
3. Animation
4. Breakpoints
5. Runtime Value Monitoring, Watch Pane
6. Console pane
7. Rule #1 - Large Simulation - Fast Debugging!
Slides:
Sample project:
0
