Automated SysML v2 Export From Teamwork Cloud to GitLab Using GitLab CI/CD Pipeline
1. Overview
This guide describes how to set up an automated pipeline that exports SysML v2 textual notation from CATIA Magic Teamwork Cloud (TWC) and commits it to a GitLab repository. The automation is triggered by TWC webhooks when a user creates a tagged commit, ensuring that every significant model revision is captured in version control as human-readable SysML v2 text.
Figure: GitLab — Repository showing exported sysml file, python script which used REST API to get sysml file, and pipeline configuration file automating process.
Figure: GitLab — Repository showing updated .sysml file and commit history
Demo:
https://youtu.be/guDRYXwZomU
Note! SysML v2 Rest API to export. sysml file will be available with v2026x R1 release 2026 July. This is early demonstration. You can use SysML v2 current REST API with other use cases like running simulation or exporting requirements.
2. Architecture
The solution consists of four integrated components working together in a fully automated workflow:
Component
Role
Teamwork Cloud
Central SysML v2 model repository. Hosts the project and exposes the SysML v2 REST API for programmatic access. Fires webhooks on tagged commits.
TWC Webhook
Configured on the TWC project to detect commits with a specific tag (e.g., "SysML"). When triggered, it sends an HTTP POST to the GitLab pipeline trigger URL.
GitLab CI/CD
Runs the sync pipeline on a self-hosted Windows runner. The pipeline executes a Python script that connects to the TWC API, exports the model, and commits the result.
Python Script
The sync_sysml.py script fetches the latest commit from TWC, exports the SysML v2 textual notation via the API, and pushes the .sysml file to the GitLab repository using git commands.
3. Automation Flow
1. A systems engineer commits changes in CATIA Magic and applies a "SysML" tag to the commit in Teamwork Cloud.
2. The TWC webhook detects the tagged commit and fires an HTTP POST request to the GitLab pipeline trigger endpoint.
3. GitLab receives the trigger and starts the CI/CD pipeline on the self-hosted Windows runner.
4. The Python script (sync_sysml.py) fetches the latest commit from the TWC SysML v2 API.
5. The script exports the SysML v2 textual notation and pushes it as a .sysml file to the GitLab repository.
6. The .sysml file is also saved as a downloadable CI/CD artifact with 30-day retention.
Key Benefit
This pipeline provides a complete audit trail of SysML v2 model changes in Git, enabling diff-based review, branch-based collaboration, and integration with existing software development workflows.
4. Prerequisites
Before starting, ensure the following are available:
•  A Teamwork Cloud server with SysML v2 API enabled (port 8443)
•  A SysML v2 project hosted on TWC
•  A GitLab instance (self-hosted or cloud) accessible from the TWC network
•  A Windows machine on the same network as TWC (for the GitLab Runner)
•  Python 3.10+ installed on the runner machine
•  Administrative access to both TWC and GitLab
5. Step-by-Step Setup
STEP 1  Create the GitLab Project
Create a new project in GitLab to store the exported SysML v2 files. This repository will serve as the version-controlled archive of your model.
1.1 Navigate to your GitLab instance and click New Project.
1.2 Choose "Create blank project" and fill in:
Setting
Value
Project name
sysml-v2-twc
Visibility
Private (recommended)
Initialize with README
Yes
1.3 Click Create project. Note the Project ID shown on the project page (e.g., 9128).
Figure: GitLab — New Project creation page
STEP 2  Install & Register the GitLab Runner
A self-hosted GitLab Runner is required because the TWC server is on an internal corporate network that cloud-based runners cannot reach. The runner must be installed on a Windows machine with network access to both TWC and GitLab.
2.1 Download the GitLab Runner binary for Windows from the GitLab documentation site.
2.2 Create a directory for the runner:
mkdir C:\\GitLab-Runner
2.3 Place the downloaded executable as gitlab-runner.exe in that directory.
2.4 In GitLab, go to your project: Settings → CI/CD → Runners → Expand. Click "New project runner" and note the registration token.
Figure: GitLab — Runner registration settings page
2.5 Open PowerShell as Administrator and register the runner:
cd C:\\GitLab-Runner
.\\gitlab-runner.exe register
# When prompted, enter:
#  GitLab URL:      https:// name>
#  Registration token:
#  Description:
#  Tags:            shell, windows
#   Executor:        shell
2.6 Install and start the runner as a Windows service:
.\\gitlab-runner.exe install
.\\gitlab-runner.exe start
.\\gitlab-runner.exe status   # Should show: running
Shell Executor
The shell executor runs CI jobs using PowerShell (pwsh) directly on the Windows host. This avoids Docker overhead and gives the pipeline native access to Python and git, both of which must be pre-installed on the machine.
STEP 3  Configure CI/CD Variables
The pipeline script requires authentication tokens to access both TWC and GitLab APIs. These are stored securely as masked CI/CD variables.
3.1 Go to your GitLab project: Settings → CI/CD → Variables → Expand.
3.2 Add the following variables:
Variable
Description
TWC_TOKEN
JWT token from Teamwork Cloud (personal access token)
GITLAB_TOKEN
GitLab personal access token with api + write_repository scope
Important: Uncheck "Protected"
Both variables must have the "Protected" checkbox unchecked. Protected variables are only available on protected branches and will not be passed to pipelines triggered by webhooks (trigger source). This is the most common cause of 401 authentication errors.
Figure: GitLab — CI/CD Variables configuration with Protected unchecked
3.3 To generate a TWC token, use the Teamwork Cloud administration panel or create a personal access token via the TWC REST API.
3.4 To generate a GitLab token, go to your GitLab profile: Edit Profile → Access Tokens. Create a token with api and write_repository scopes.
STEP 4  Add Pipeline Files to the Repository
Two files are needed in the GitLab repository: the CI/CD configuration file and the Python sync script.
6. .gitlab-ci.yml
Create this file in the root of the repository. It defines the pipeline stages, triggers, and script execution.
stages:
 - sync
variables:
 GIT_STRATEGY: clone
 GIT_DEPTH: 0
sync_sysml_from_twc:
 stage: sync
 rules:
   - if: \\\$CI_PIPELINE_SOURCE == "schedule"
   - if: \\\$CI_PIPELINE_SOURCE == "web"
      when: manual
   - if: \\\$CI_PIPELINE_SOURCE == "trigger"
 script:
   - pip install requests --quiet
   - python scripts/sync_sysml.py
 artifacts:
   paths:
      - "*.sysml"
   when: on_success
    expire_in: 30 days
GIT_STRATEGY & GIT_DEPTH
GIT_STRATEGY: clone ensures a fresh clone each run (avoids stale state). GIT_DEPTH: 0 fetches full history, which is required for git push to work from the runner. Without these, the runner operates in detached HEAD mode and cannot push commits.
7. scripts/sync_sysml.py
Create a scripts/ directory in the repository and add the sync script. This Python script performs the actual work of fetching from TWC and pushing to GitLab.
The script performs these operations:
1. Connects to the TWC SysML v2 API using multi-auth fallback (no auth, Token, Bearer)
2. Fetches all commits and selects the latest one
3. Checks the last_synced_commit.txt tracking file to avoid duplicate syncs
4. Retrieves the root namespace and exports SysML v2 textual notation
5. Falls back to element-based reconstruction if direct export fails
6. Commits and pushes the .sysml file and tracking file to GitLab using native git
Key configuration values (hardcoded defaults, overridable via CI/CD variables):
Parameter
Value
TWC_BASE_URL
https:// server>:8443/sysmlv2-api
TWC_PROJECT_ID
API Path: Commits
/api/projects/{id}/commits
API Path: Roots
/api/projects/{id}/commits/{cid}/roots
API Path: Textual
/api/projects/{id}/commits/{cid}/textual/{ns_id}
API Path: Elements
/api/projects/{id}/commits/{cid}/elements
Accept Header
application/json
Output File
Stock Market Ticker.sysml
Critical: API Path Prefix
The TWC SysML v2 API uses /api/ as a prefix in all endpoint paths. For example, the commits endpoint is /api/projects/{id}/commits, NOT /projects/{id}/commits. Missing this prefix results in 404 errors.
The full script file (sync_sysml.py) is provided as a separate attachment to this document. Place it at scripts/sync_sysml.py in the repository.
8. Repository Structure
After setup, the repository should have this structure:
sysml-v2-twc/
├── .gitlab-ci.yml                 # Pipeline configuration
├── scripts/
│  └── sync_sysml.py              # TWC sync script
├── Stock Market Ticker.sysml      # Auto-generated SysML export
├── last_synced_commit.txt         # Tracks last synced TWC commit
└── README.md
STEP 5  Create a Pipeline Trigger Token
A pipeline trigger token allows external systems (like TWC) to start pipelines via an HTTP POST request.
5.1 In GitLab, go to: Settings → CI/CD → Pipeline trigger tokens → Expand.
5.2 Click "Add new token" and provide a description (e.g., "TWC Webhook Trigger").
5.3 Copy the generated token. It will look like: glptt-xxxxxxxxxxxxxxxxxxxx
Figure: GitLab — Pipeline trigger token creation
5.4 Test the trigger from PowerShell:
# Bypass SSL certificate validation for self-signed certs
[System.Net.ServicePointManager]::ServerCertificateValidationCallback = {\\\$true}
Invoke-RestMethod -Method POST `
 -Uri "https://api/v4/projects/9128/trigger/pipeline" `
  -Body @{token="glptt-xxxxxxxxxxxxxxxxxxxx"; ref="main"}
If successful, the response will contain a pipeline ID and status "created".
STEP 6  Configure the TWC Webhook
The final piece connects TWC to GitLab by configuring a webhook that fires when a tagged commit is created.
6.1 Open the Teamwork Cloud administration panel (typically at https://your-twc-server:8443/admin).
6.2 Navigate to: Webhooks → Add webhook.
6.3 Configure the webhook with the following settings:
Setting
Value
URL
https:// server>/api/v4/projects/9128/trigger/pipeline?token=glptt-xxx&ref=main
Scope
Resource (select your SysML project)
Event
Tagged commit
Tags
Major, major
Enabled
Yes (checked)
Figure: Teamwork Cloud — Webhook configuration panel
6.4 The webhook URL includes the pipeline trigger token and branch reference as query parameters. When TWC fires the webhook, it sends a POST to this URL, which GitLab interprets as a pipeline trigger.
Tag Filtering
The webhook is configured to only fire on commits tagged with "Major" (case-insensitive). The sync script itself does NOT filter by tag — it always syncs the latest commit. This separation of concerns means the webhook controls WHEN the pipeline runs, while the script controls WHAT gets exported.
STEP 7  Test the End-to-End Flow
With all components configured, test the complete automation:
7.1 Open your SysML v2 project in CATIA Magic.
7.2 Make a change to the model (e.g., update a requirement text).
7.3 Commit the change to Teamwork Cloud and apply the "Major" tag.
7.4 Check GitLab → Build → Pipelines. A new pipeline should appear within seconds.
Figure: GitLab — Pipeline running after TWC webhook trigger
7.5 Once the pipeline completes, verify:
  •  The .sysml file in the repository is updated with the latest model content.
  •  The last_synced_commit.txt contains the TWC commit ID.
  •  A downloadable .sysml artifact is available on the job page.
9. Troubleshooting
Symptom
Cause
Fix
HTTP 401 from TWC API
TWC_TOKEN variable is missing, expired, or marked as Protected
Ensure TWC_TOKEN exists in CI/CD Variables and that "Protected" is unchecked
HTTP 404 from TWC API
Missing /api/ prefix in endpoint paths
Verify all API paths include /api/ (e.g., /api/projects/{id}/commits)
HTTP 403 from GitLab API
Token scope insufficient or branch protection
Use git push method instead of API; ensure GITLAB_TOKEN has write_repository scope
Pipeline not triggered
Webhook misconfigured or tag filter mismatch
Verify webhook URL, check TWC webhook logs, test trigger manually via PowerShell
"Already synced" message
last_synced_commit.txt matches latest TWC commit
Delete last_synced_commit.txt from the repo to force re-sync
git push fails
Missing GIT_STRATEGY: clone or GIT_DEPTH: 0 in CI config
Add both variables to the .gitlab-ci.yml file
Empty SysML export
Textual notation not available for the commit
Script automatically falls back to element-based reconstruction
10. Quick Reference
Item
Value
TWC Server
:8443
TWC API Base
/sysmlv2-api/api/
GitLab Instance
itgit.dsone.3ds.com
GitLab Project
SPS6/sysml-v2-twc (ID: 9128)
Runner
(shell/pwsh, Windows)
Branch
main
Output File
Artifact Retention
30 days
11. Files Provided
The following files accompany this document and should be placed in the GitLab repository:
File
Repository Path
.gitlab-ci.yml
/ (repository root)
sync_sysml.py
/scripts/sync_sysml.py
For questions or issues, review the pipeline job logs in GitLab (Build → Jobs) for detailed diagnostic output from the sync script.
