We're back with our next set of PPX Tips & Tricks! Our goal is to share some of the shortcuts and helpful hints when creating design project presentations with CATIA Product Perception Experience.
Multiple variants from a multi-selection
This works with all actor-based variants: Product, Position, Material, Human and Physics Simulation Result. And it's new since R2022x HF1 (FD01).
Save As... your design presentation
Hide the "new variant line" icons
Invisible objects as variant triggers
Invisible objects can also be used as trigger objects. To do so: create a primitive, place it and resize it, define it as a trigger, and finally, using the Properties Panel, set its Transparency to 0. Do not hide it (its Visible property must still be checked).
Of course, the Highlight Triggers command will still highlight them when you need to remember where such objects are.
I used suck trick a few times, but I'm curious to know if you ever faced a use case where such tips would have been useful ;)
More
Next Tips & Tricks post
Previous Tips & Tricks post
Product Experience Tips & Tricks Product Design Presenter role
