Since the upgrade of R2026xFD03 , it is no longer possible to save ENOVIA Documents containing DWG or DGN files.
Here is the symptom :
We discussed with ENOVIA R&D to fix this situation.
Conclusion :
- Implementation change: Remove DWG and DGN file extensions from the default unsupported file list.
- Documentation: Record this change in the Program Directory.
- Release Planning: Promote the fix for R2026xFD04 and R2027xMajor. PinPoint for R2026xFD03
Sorry for the inconvenience if you encounter this issue.
If you are blocked, I can give the bypass. Please contact me in this case.
