HighCharts HeatMap
I'm trying to use Highcharts Chart component to display HeatMap. But values are of the same color and it seems not possible to define a gradient.
Can you help me ? Thanks
Comments 4
AC
AC 2020-05-07
I would suggest using the Heat Map (HTML5) component, which does work with your data and produces a heat map with the appropriate colours. The component you were using (Highcharts Chart) is an internal component that is not meant to be used directly. I've attached your example modified to use the Heat Map (HTML5) components.
comment imagecomment image
SV
SV 2020-05-07
Thanks Andrei, there is also a good example that uses that very component. It's called the 'Clickable Heat Map​', and you can find it under Protocols/Examples/Dashboards/How-To/Drilldown/Clickable Charts. Also another one just about colours Protocols\Examples\Dashboards\Charts\Heat Map Demos. The other protocols in the same folder are quite nice too. Enjoy, that's much easier than using the internal Highchart Chart component :)​
CB
CB 2020-05-12
Good, I've got it :  Heat Map (HTML5) component is based on  Highchart internal component . That's what I wanted. So, I was able to dig and play, with Highcharts options
CB
CB 2020-05-12
Now I would like to use export options : I first add exporting.js library to the component but where can I put navigation/buttonOptions parameter ?
