Coronavirus tracker
All,
The attached Pipeline Pilot protocol uses daily-updated data from the Johns Hopkins github repository to create plots of COVID-19 cases and deaths by country or province as a function of time. You may find it useful for tracking the progression of the pandemic in different locations.
Best regards,
Dana
Comments 7
AM
AM 2020-03-06
i cannot do anything with this file.. a little explanation would be interesting... we are following virus progression from JH Univ directly. Can you explain what your tracker does and how to use it?  thank you
SA
SA 2020-03-06
More info, and some rather nice dashboards, here https://github.com/CSSEGISandData/COVID-19
I couldn't read the files directly into PP (firewall/config probably) but downloading the files manually and reading them in worked fine.
PC
PC 2020-03-06
Hi Ariel,
I managed to download the file, so perhaps the issue is resolved?
But I've also used this protocol as a basis for a blog, presenting the data in Google maps. That can be found here:
http://www.finiaconsulting.com/blog/2020/03/plotting-spread-of-coronavirus-using-google-maps/
I've included a bit of an explanation of the data there, but mostly it's about how to handle that data and produce an interactive map report.
The work I present requires a GIS package I've written for Pipeline Pilot and enables plotting of data to things like Google maps.
LH
LH 2020-03-06
Worked fine for me - Sarah, must be a firewall issue for you. Usually I have those issues, but not so this time.​
DH
DH 2020-03-06
Just to clarify: The attached file is a .zip file containing a Pipeline Pilot protocol in the form of a .ppxml file. Unzip the file, and then open the .ppxml file in Pipeline Pilot and run it. The graphs will then appear in a browser window.
SL
SL 2020-03-27
thanks dana
DH
DH 2020-03-27
The location of the Johns Hopkins data has changed, so you will need to change the Source parameters of the Delimited Text Readers in the original protocol to get it to work. Attached is an updated version that uses the new locations and also allows you to select which countries' data to plot.
comment imagecomment image
