Workbook Pre-Configuration 2021SP1HF1 times out while configuring Windows Features if the “SxS” (side-by-side) directory, which has the installation files necessary to add the required features is missing.
Error from Workbook_Pre-Configuration.log
Install-WindowsFeature : The server could not update the provided feature files in the time allowed.
At C:\\Users\\pxb001\\AppData\\Local\\Temp\\pss8030.ps1:1 char:483
+ ... \\\$result = Install-WindowsFeature Web-Asp-Net, Web-Lgcy-Mgmt-Console ...
+ CategoryInfo : OperationTimeout: (c99a41ad-0673-4d16-839a-e44ca24d57b3:Guid) ,
Exception
+ FullyQualifiedErrorId : GetAlterationState__CallCycleTimeout,Microsoft.Windows.ServerManager.Commands.AddWindows
FeatureCommand
Error 4180. There was an error during the Windows features configuration process.
Your original configuration will be restored.
Solution:
Re-image the server so that there are no missing source files.
Workaround:
Mount the DVD drive on the Vault server to point to the missing source files and re-run the Workbook Pre-Configuration 2021SP1HF1.exe.
This information is documented in the Workbook 2022 system requirements with a note as shown below.
Note: The operating system deployed must have a properly installed WinSxS directory used to install Microsoft roles and features like IIS.
