If you name the vault server certificate as vault.pfx, you receive an error given below during the vault installation.
- Installing Renaming 'vault.pfx' to 'Vault.pfx' in 'C:\\Program Files (x86)\\BIOVIA\\Vault\\VaultClientService\\conf'.
- Exception occurred: System.IO.FileNotFoundException: Could not find file 'C:\\Program Files (x86)\\BIOVIA\\Vault\\VaultClientService\\conf\\vault.pfx'.
File name: 'C:\\Program Files (x86)\\BIOVIA\\Vault\\VaultClientService\\conf\\vault.pfx'
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.File.InternalMove(String sourceFileName, String destFileName, Boolean checkHost)
at Accelrys.Vault.Setup.Install.FileRenameCommand.Install()
at Accelrys.Vault.Setup.Install.LoggerExtensions.LogActivity(Logger logger, String description, Action toLog)
- Uninstalling Copy 'C:\\Certs\\\\vault.pfx' file(s) to 'C:\\Program Files (x86)\\BIOVIA\\Vault\\VaultClientService\\conf\\'.
Defect NBK-33807: 'Vault server certificate pfx file cannot be named as vault.pfx' entered for this in BIOVIA Jira system.
Workaround: Rename the certificate pfx file from vault.pfx to something different for example, vaultservername.pfx and rerun the vaultsetup.
