BIOVIA just released BIOVIA Direct 2022 SP1 HF1 that fixes two issues regarding the perception of aromaticity and meso structures.
It now turned out that the initial license check to unpack the installation files for the Linux version of that hotfix is broken. Therefore, the Linux hotfix currently cannot be installed from the published installation script.
BIOVIA is working on this issue.
Update 30-AUG-2022: BIOVIA will release an updated hotfix, 2022 SP1 HF2, that fixes the problem. As 2022 SP1 HF1, the HF2 will be a complete release of BIOVIA Direct, and it is supposed to replace the HF1.
The only change in the 2022 SP1 HF2 will be the fix of the Linux installer, no code changes are made to the Direct application beyond those made for the HF1.
If you have already installed the 2022 SP1 HF1 into a Windows environment, there is no need to upgrade to the HF2 as the application code has not changed. Please be aware however that the HF2 release will have a different build number than the HF1 release.
The 2022 SP1 HF2 is scheduled to be released end of September 2022. If you you need this HF2 before that please open a ticket with Dassault Customer Success.
BIOVIA apologizes for the inconvenience.
