Program
BIOVIA CISPro 2023
Description
We are providing this Technical Note to inform you about the release of BIOVIA CISPro 2023 Golden, which includes the following enhancements and fixed defects:
Enhancements
User Story | Description |
CIS-67664 | Inventory API now supports obsoleting entities. See the Inventory API documentation for more information. |
CIS-73714 | Existing batches can be opened directly from the batch number on the Batch page. The Batch page is now available in the Select a View menu and can be added as a home page item. |
CIS-74329 | Added the ability to navigate from CISPro to Hub from the CISPro main menu. |
CIS-74587 | A warning message now displays on the Mobile Kiosk Dispensing and Batch pages if the container entered is expired. |
CIS-74605 | Added the ability to print labels when opening containers in Mobile Kiosk. |
CIS-74973 | Renamed the "Add Material" tab in the Mobile Kiosk Dispensing page to "Add" to better reflect that quantity is being added to the container, not another material. |
CIS-74974 | Renamed the "Lot #" and "Part #" fields in the Mobile Kiosk Dispensing page to "Manufacturer Lot No" and "Part No" respectively to ensure consistency across interfaces. |
CIS-74999 | Administrators can now define if users have permission to approve change requests by granting or revoking the "Approve Change Request" action permission at the role level. This permission is granted to all roles by default to maintain current behavior. Administrators should review role permissions after this upgrade. |
CIS-75277 | Added a new Mobile Kiosk page for performing "Transfer by Location" (update container owner based on location's responsible user) and "Transfer by User" (update container location based on user's default location) actions. |
CIS-75359 | Inventory API now supports deleting entities. See the Inventory API documentation for more information. |
CIS-75492 | The default value for the "SketcherURL" setup variable in CswConfigUX is set to blank. |
CIS-72277 | Added the ability to combine all or a portion of containers of the same material using the Mobile Kiosk Pooling page. |
CIS-75274 | Seal Number is now required when locking a container group. When a container group is unlocked, the Seal Number will be cleared. |
CIS-60319 | Owner and location can now be set when dispensing to a child container. |
CIS-75360 | "Microsoft Access Database Engine" is no longer a system requirement. |
Fixed Defects
Defect | Description |
CIS-74975 | Custom provided barcodes are now case-insensitive. |
CIS-75081 | Materials associated with regulatory lists through a constituent can now be successfully approved. |
CIS-75455 | Special character values for comment properties are now truncated correctly when the comment value exceeds 4000 characters. |
CIS-75547 | E-signatures are now validated as expected when disposing a container in Kiosk Mode. |
CIS-75578 | Export any report driven grids to CSV when user is in GMT time. |
CIS-73467 | An error message received when fulfilling requests for freezer inventory no longer displays "null". |
CIS-73949 | Inventory API can now remove unwanted selected options from ImageList and MultiList type properties. |
CIS-74651 | Special characters of print job's gestalt will truncate under 4k bytes. |
CIS-74885 | Component Concentration Units options when adding a new Component during material creation, are now scoped to those with a Functional Scope of "Concentration". |
CIS-75304 | The Dispense History on the Batch page displays a negative sign if the amount dispensed into the batch was negative. |
CIS-75429 | Users without Regulatory List Material permission to request are prevented from submitted a request for a Receipt Lot when the request is submitted from the search results page. |
CIS-75459 | Material Type now displays on the create material page when importing from Data Mart. |
CIS-75491 | Administrators can now edit entity name templates when the entity type has outstanding change requests. |
CIS-75503 | Entities of all types can successfully be deleted when using the approvals feature. |
CIS-75548 | E-signatures are now validated as expected when undisposing a container in Kiosk Mode. |
CIS-75550 | E-signature reason options can now appropriately handle newline characters. |
CIS-75565 | When submitted, requests in the Cart now correctly move to the Submitted tab. |
CIS-75621 | Deleting Sizes from the Create Material page no longer causes issues with Size creation after submission. |
CIS-75808 | Copy to Recurring now correctly loads the Recurring tab. |
CIS-75859 | Enhanced Schedule Service's "PurgeSessionData" rule to support additional data conditions related to Request Items. |
CIS-69433 | Regulatory list association no longer fails if the property name being used for association contains a single quote character. |
CIS-75346 | During approval of new Material Synonyms, CISPro now ignores obsoleted Synonyms when performing validation checks. |
CIS-75906 | A console error no longer appears in the Mobile Kiosk pages. |
Resolution
BIOVIA CISPro 2023 Golden was released in December 2022 and is available for download at https://software.3ds.com under BIOVIA > Product line: Lab, Scientific and Content Solutions > Release: BIOVIA 2023 > Level: BIOVIA 2023 Golden
How to contact BIOVIA Support
If you have any questions, please contact BIOVIA Support.
