Steps to configure BIOVIA Direct after upgrade from Oracle 12 to Oracle 19C.
You need to perform the steps listed below to configure BIOVIA Direct after upgrade from Oracle 12 to Oracle 19C. If not, you will see ORA errors listed below.
ORA-06520: PL/SQL: Error loading external library
ORA-06512: at "C\\\$DIRECT2021.MDLAUXOP", line 2364
ORA-06512: at "C\\\$DIRECT2021.MDLAUXOP", line 2361
Steps to be Performed:
1. Edit listener.ora and correct the LD_LIBRARY_PATH to point to bin19 for example, u01/app/BIOVIA/DIRECT2021SP1/bin19
2. Restart the database listener and DIRECT2021 listener.
3. Edit mdllibdef.sql in the folder u01/app/BIOVIA/DIRECT2021SP1/sql to correct the path to point to bin19.
4. Connect as system and run mdllibdef.sql
5. Connect as system and run mdltestlistener.sql from u01/app/BIOVIA/DIRECT2021SP1/sql folder
6. Connect as C\\\$DIRECT2021 schema and run the command below to verify that BIOVIA Direct is working without any ORA errors.
Select mdlaux.version from dual;
7. Connect as each schema used by BIOVIA Direct, for example, SYMYXDB and run the following commands and verify there are no ORA errors.
execute mdlaux.unsetup;
execute c\\\$direct2021.mdlauxop.setup;
select mdlaux.version from dual;
