During Pipeline Pilot upgrade, setting permissions on the \\PPS\\web folder may take a long time if the \\PPS\\web\\jobs folder is huge. During the pre-check prior to the upgrade, you can log into Pipeline Pilot Admin portal and set the 'Maximum Job Age Based on Job Folder Size' setting under Setup>Job Settings. You can set this setting based on Size (KB, MB, GB) or Max Age (d, w, y) and click Save. This will clean up the jobs folder and reduce the size so that setting permissions on the \\PPS\\web folder will not take a long time during the upgrade. This will reduce the upgrade time of Pipeline Pilot server.
