In an attempt to migrate newly added/modified Salts from one Chemical Registration environment to another, users might try to use the GEMS Metadata export-import procedures. This should be avoided because this will update only the salts vocabulary and not the CRS_SALTCLOB table in the target environment.
The recommendation is to use the Export Salts and Solvents protocol in the source environment (e.g., DEV environment) and then use the Import Salts and Solvents protocol in the target environment (e.g., PROD environment) to bring the changes. Migration using the Export/Import Salt and Solvent protocol will update both the CRS_SALTCLOB and EMS_VOCAB_ENTRY tables. These protocols are located in the Protocols tab under Utilities > Chemical Registration in Pipeline Pilot client.
