Chemical Registration users might be interested in retrieving data for records that were retired from the database. For this purpose, they can use the "Read Lot for Each Data" component available under “Components\\Web Applications\\Chemical Registration\\Utilities\\” in Chemical Registration. This component includes a parameter called "Ignore Retired Records" which is set to True by default. With this default setting, a retired record will be sent to the Fail Port with the message 'Ignoring retired instance'. Users interested in retrieving data for retired records should change this parameter value to "False" when using this component.
The information in this article will apply to retrieving data for retired records from BioReg database as well. Users can use the "Read Lot for Each Data" component available in “Components\Web Applications\Biological Registration\Utilities\” folder and set the "Ignore retired records" parameter value to False.
