August 1st US-East 3DEXPERIENCE platform service disruption
Event summary
On August, 1st 2017, all US East Cloud Services were fully unavailable to all users.
The outage started at 08:30 am EDT and service was fully restored at 13:30pm EDT.
Event Description and Root Cause Analysis
At 08:30 am EDT, all VM instances running on US East region became unreachable: although appearing to be up & running, VM instance access was not possible, resulting in no access to DS Cloud Services.
VM instances became unavailable during an IaaS standard maintenance operation: the maintenance consisted in deploying new code on multiple IaaS components. This is the kind of operation that is normally performed on a daily basis without any difficulty. However, during this operation, all network access rules were suddenly and unexpectedly removed from firewall components implementing the users’ security groups. This caused the VM instances to be isolated from the network. In addition, all Elastic IP mappings and associated NAT configurations were lost (as those were firewall configurations also).
After the symptoms were identified, we rolled back the code updates. We then properly shutdown all VM instances (by using the IaaS APIs), and were able to restart all Cloud Services by restarting VM instances and reapplying all network configurations.
Post-mortem analysis revealed that the issue was introduced by a race condition during the deployment, causing an incoherency in the IaaS inventory used by all IaaS components that resulted in a flush of all firewall configurations: some critical code locks were not set during our deployment process, causing the code to be potentially executed, involving multiple coupled components that were not yet updated, and then causing incorrect behavior.
Event Remediation and Prevention
Full RCA has been done by the IaaS provider since the outage, the following action items have been identified and setup:
  1. Deployment methodology has been changed to ensure atomicity while deploying piece of code that are strongly coupled.
  2. Testing methodology has now additional steps involving tests in a staging environment with high load and activity.
Final Comments
All events impacting the availability of our 3DEXPERIENCE platform on Cloud are analyzed in detail and we are especially attentive and concerned with the outages that impact our users.
We apologize again for the inconvenience those events caused. We performed a deep root cause analysis and have implemented detailed action plans to avoid any new occurrence of those incidents. Please rest assured that Dassault Systèmes priority is to offer you the best reliable service.
Sincerely,
David DE MUER
VP WW R&D Operations & Customer Success | Dassault Systèmes
