3DEXPERIENCE Platform R2018x FD02 - Fixed issues
Dear all,
Please find attached the list of all fixed issues on R2018x FD02 level.
You can find details about each of this BUG Report by searching directly its reference in the KB
click hereUnable to view Catia V6 Physical Product in 3DPlay from change action or from Physical Product screens
click herewire-frame line is generated and 3dmodel becomes small
click hereCustom 6W Tag doesnt appear in Attribute Configuration
click hereExport Building Information Modelling structure optimization
click hereExport drawing to dxf: Pattern is not exported correctly
click hereDrawing: missing elements in section view after migration on R2018x
click hereLength parameter automatically changes value when re-editing (in-ft)
click hereFluidic Manipulator Handles not Selectable when using Volatile Ghosting
click herePiping & Tubing 3D Design App - "Duplicate/Mirror Instances" command doesn't mirror Flexible pipes correctly. The resulting flexibles are duplicated in the same place.
click hereRendering : Material flakes looks bigger
click here
Exporting a Step file is missing Electrical Branches.
click hereWhen mirrored piping layout is exported as Step (.stp) file, some of the fittings in incorrectly oriented.
click herePublish date of a draft is not displayed correct on the community wall in MY Contributions (it displays the date when the post was kept as draft)
click herethe total number of members displayed is "members" column and community statistics are different "members" column displays the total count of members including denied,anonymized and removed members also
click herePost corresponding to shared URL is not opened on the screen if user is not already logged in to platform
click hereThe 3DEXPERIENCE Structural Validation app fails to create the 'Bolt Replication' feature for a model involving multiple instances of a 3DPart when the 'Bolt Replication' feature exists for one of the instances of the 3DPart.
click hereDashboard shows request count of removed users
click hereuser  not found on typing firstname and /or lastname also When entering an email, the platform should suggest a user and present it as Firstname LASTNAME. In this case the platform only displays the email addre
click hereSet tool function does not take fully into account additional mount port belonging to the mount part of the robot
click hereA particular Simulia Fluid Scenario analysis aborts without recording any results
click hereManakin data Library Manager command / performance issue
click here3DXCity: Unable to drag drop data from 3DSpace to City Referential app
click hereRich Client Installation with proxy.pac file
click hereCannot import SOLIDWORKS 2018 part (SLDPRT) and assembly (SLDASM) files
click hereCannot Create Librabies Public Cloud Governance/Lifecycle / 3DEXPERIENCE
click hereTrying to restore previous iteration of a part doesn't work
click hereIn the 3DEXPERIENCE Fluid Scenario Creation App, when EOS property is specified for a material along with density, the simulation aborts with inadequate error message.
click hereBusiness Innovation Tooltip is missing
click hereRequest role notification from some users keeps loading
click hereTooltip only shows for last row in members role page
click hereProfile picture of Members is not visible in members tab
click hereWhen renaming a Task in the WBS view, you do not get access twice to the same field
click hereno email notification is received when timesheets are submitted or rejected
click hereWhen a "subject" goes beyond one line, the schedule "gates" do not extend vertically
click hereCore Dump when modifying the 3D Accuracy and 2D accuracy values
click hereIntermittent freezing after Eng template instantiation
click hereIn the Abaqus Study App, when the generate 3DEXPERIENCE Result option is used on a sim file, a result object with generic title is generated.
click here3D Merchandising / StoreStudio: Function "Align" in store studio doesn't work on a hanging Bar"
click hereNumbering error and detection numbers error in book merchandising
click hereMedia does not appear in the right column of the community
click hereSince R2018x Upgrade, For some post and wiki pages 'eye icon' which represents views is displaying count '0'
click hereIn the 3DEXPERIENCE Physics Results Exploration App, the option to transform rotation results on user defined coordinates is not available.
Comments 1
JJ
JJ 2018-04-13
@EH - thank you
