I am running into an issue where I want to rename a folder that holds a solidworks drawing and a solidworks part but when I do the drawing views break.
When I rename the folder, the drawings views break and become phantom boxes, however I can still right click the phantom box and it opens the part without issue in the correct folder.
When I open the drawing and do file>find references the drawing and part both have the correct "In Folder" location of the renamed folder location.
When I Pack and Go the drawing+part into a new folder location, the drawing works properly with no broken references.
Has anyone encountered this issue? I would like to protect my files in the event a folder is renamed by someone else in my organization.
I think your choices are: 1) Make it a policy to not rename folders, or 2) Start using PDM.
Without PDM, renaming a folder will break the references.
In my case (SolidWorks 2019 SP3.0 and previous), renaming a folder that contains both drawing and part, both files stay fully correct and show correct references. This might be helped by the fact that I don't want SolidWorks to search for referenced files in other locations than what the reference indicates. For this, I have created multiple Phantom directories, to direct to in the System Options.
This entry has a question in it and not an idea for enhancement so marking as out. You can still see this and engagements can continue – it just won't be part of the funnel. If you still need help, please re-add as a Question in the community. Thank you.
Go to open drawing from within Solidworks, select the drawing file(don't open it) at the bottom of the window click references, update the part/assembly names and the file path. (they should turn green after updating) then open the drawing and everything should be back to normal.
