I am seeing issues on the PDM explorer in windows 10, the text scaling and alignment runs into itself. Additionally, I am missing the button to export a BOM in PDM. Any ideas on how to fix this?
Hi Patrick. May I suggest that you repost this using the Question category instead. The Ideas category is for suggesting new enhancements to the SOLIDWORKS software and/or the 3DSWYM community/forum app. Technical questions and troubleshooting requests will get a lot more visibility when using the Question category.
Patrick,
from the screenshot I think you are using a high resolution screen with a high-DPI scaling setting (such as 150% scaling etc.). Depending on what version of SOLIDWORKS PDM you are running, older versions (2019 and older) did not handle this too well and could lead to truncated icons, columns and menus. Most common DPI scaling problems should be addressed in SWPDM 2020 and later.
If you are on a current release, the UI can look weird after changing scaling settings without a reboot. So I'd try that as well.
Get in touch with your VAR to get help troubleshooting this further.
-Tor
This is not an idea for enhancement so marking as out. You can still see this and engagements can continue – it just won't be part of the funnel. Please re-add as a Question if you still need help. Thank you.
