TESLA VALVE (WALWUAR CONDUT PATENTED FEB 3, 1920 - N. TESLA)
The conventional check valves used in fluid systems rely on mechanical moving components such as springs, balls, or flaps to control the direction of flow. These moving parts are prone to wear, fatigue, leakage, and failure over time, especially when exposed to high temperatures, corrosive fluids, or particle-laden flows. As a result, they require frequent maintenance and are unsuitable for miniature or high-precision flow control applications.
To overcome these limitations, Nikola Tesla proposed a passive, no-moving-parts valve—commonly known as the Tesla valve—which utilizes geometric asymmetry and flow inertia to create high resistance in the reverse direction and low resistance in the forward direction. This self-actuating valve can operate reliably under varying flow conditions without any external control or maintenance.
